Re: 574D fuel return check valve
Posted by JJK on April 02, 2005 at 14:23:18 from (216.189.131.154):
In Reply to: 574D fuel return check valve posted by I can't use even my name on April 02, 2005 at 14:04:36:
You can put a regular fitting back in but if you need to split the tractor or have to disconnect the line there won't be anything to stop the fuel from running out until you can plug it with something. These fittings have been known to plug when the spring breaks in the valve and fuel pressure build up and pushes fuel through the front seal of the injection pump and into the crankcase.
Post a Followup
Today's Featured Article - Major Problems - by Anthony West. Following the aquisition of the two Fordsons to my collection I found that I was struggling to move them about. I had considered the possibility of driving the "F" to and from shows but anything other than local rallies was totaly impractical due to its sedate pace. I had also considered buying a landrover and trailer, but the price of a ... [Read Article]
