Farmall Tractors Discussion Board
Re: WIDE narrow
Posted by MrGadget on December 04, 1999 at 20:38:54 from (205.240.115.10):
In Reply to: WIDE narrow posted by T'other Fred on December 04, 1999 at 19:02:17:
Narrow fronts are popular on "row crop" tractors for several reasons. As mentioned, compaction is a factor. But also when corn is over knee high and you are trying to cultivate for the last time (or "lay-by" to hill it out) a wide front with its lower clearance will snap the stalks clean off. Also you can't very easily mount a cornpicker on a tractor wide wide front.
Wide fronts are more stable on uneven ground due to the rocker effect of the main beam. John Deere (amd maybe others...I don't know) had a "roll-a-matic" narrow front that allowed each of two front wheels to roll up/down in opposition to smooth out the ride.
Wide fronts are MUCH more stable on hillsides as they effectively spread the stance out over a wider area, like the Pontiac commercial "wider is better" for sloping ground.
Narrow fronts are also less stable (side to side) for loader use. A narrow front won't work very well working to level and pack haylage or corn sillage.
It's more a matter of what you intend to use the tractor for that determines what type of front end is best for that application.
Post A Followup
: Re: Re: WIDE narrow
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series). ... [Read Article]
