Re: Casey's Disk
Posted by Hugh MacKay on March 15, 2005 at 04:54:05 from (209.226.247.125):
In Reply to: Re: Casey's Disk posted by caseyc on March 14, 2005 at 19:22:43:
casey: If the price is right I wouldn't hesitate. I had a Bush Hog 20' disk and from Allan's photo, much the same configuration. Mine had 20" blades.
1066 with duals and no weight added, pulled it quite easily. I had stones, so prefered pulling it with 100 hp Deere. My cowboys couldn't get much over 4 mph with Deere, which suited me fine in the stones. One thing I found with this disk was leave the wings up behind 656 and 560, man that thing would cut with the added weight from wings being up. Look at it this way, you will have a larger tractor in future.
I tried out a 766 diesel once, and while I didn't have it hooked to disk, I think it would handle that disk with controlled depth, it may take duals. Just think what you can do if you really want to cut deep for some reason. 766 is quite a bit more tractor than specs make it out to be. When I tried out the 766, had it on 5x16 semi mount plow, plowing old pasture that hadn't been turned in 50 years. I couldn't say it really worked the tractor.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
