Re: 454 charging problem
Posted by El Toro on February 27, 2005 at 04:20:14 from (205.188.117.13):
In Reply to: 454 charging problem posted by n8terry on February 26, 2005 at 21:53:29:
Is the battery fully charged? Check the electrolyte in each cell. These readings should be close to one another should read from 1250-1275
on a fully charged battery. The output voltage of 14 volts is good. I think that's normal for an amp meter to show a slight discharge when the ignition is turned on. If you do not have to add water to the battery often, I think your charging circuit is ok. Hal
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
