Re: A 414 Fuel Pump timing
Posted by Opa A on February 15, 2005 at 22:17:18 from (161.184.42.209):
In Reply to: A 414 Fuel Pump timing posted by Mike414 on February 15, 2005 at 14:15:06:
Been a while since I've timed a CAV/Lucas injection pump, bear with me. If you pull the rectangular cover off the side of the pump (held on with 2 small bolts) you will see the side of the cam ring. It will have a scribe mark on it the you can see move in the window as you turn the pump driveshaft. When that scribe mark lines up with the square end of the snapring holding the camring in the pump body, the pump will be at start of injection. You need to know the static timing mark used for setting start of injection, usually either marked on the flywheel or front pulley, not sure on a 414, but on many engine it is right at TDC. Rotate the crankshaft in the direction of engine rotation, (to take up any lash in the timing gears) until the engine timing marks line up, with #1 cylinder on top of compression stroke. At that point match the marks in the pump and lock her down to the front plate. Turn the crankshaft back 45 degrees and bring it forward again and recheck both sets of marks. Readjust if needed, reinstall window cover plate and bleed pump. Guessing on fuel pump timing and getting too much advance can be fatal to the engine if it is expected to work hard. I refuse to use the external scribe marks on the pump and front front cover, seen them out by over 1/8 inch on a regular basis. Hope this helps.
Home
| Forums
Today's Featured Article -
Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
