Re: 6 volt starter with 12 volt system
Posted by Andy Martin on January 17, 2005 at 12:46:20 from (64.219.39.195):
In Reply to: 6 volt starter with 12 volt system posted by Darin S. on January 17, 2005 at 09:54:44:
We've beat this to death.
But the attitude that 6v starters are somehow inadequate is just not true.
I ran my old 54 Chevy over 100,000 miles on 12v with no starter problems. All local trips.
All my working tractors are 12v M's and H's with 6v starters. Although I try to maintain my equipment, when the points get a little burned, a little water gets in the gas, the plugs foul, etc., they still get started and we don't worry about a little extra cranking until the batteries start getting cranked down.
The starters just don't burn up.
Post a Followup
Subject:
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
