Re: 6 volt starter with 12 volt system
Posted by farmalljim10 on January 17, 2005 at 12:32:16 from (66.244.93.65):
In Reply to: 6 volt starter with 12 volt system posted by Darin S. on January 17, 2005 at 09:54:44:
On tractors with distributor ign. there is no problem. With a mag. there could be a problem if and only if it turns it over so fast as not to let the impulse work then it might get less spark than if the inpulse was working but you can Normally hear if the impulse is working .If you know what to listen for. (a snapping sound ) .Otherwise use what you got till it doesent work then maybe replace it with a 12 volt starter..Latter 140 had 12 volts I am not sure about 240s.But the starters should be the same.
Post a Followup
Subject:
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
