Re: 6 volt starter with 12 volt system
Posted by gusc on January 17, 2005 at 11:43:58 from (63.97.117.24):
In Reply to: 6 volt starter with 12 volt system posted by Darin S. on January 17, 2005 at 09:54:44:
Andy has it down pat. A motor is rated in watts or hp. Since 745 watts = one hp a one hp motor will only draw 745 wats (basically volts x amps) regardless of the amp/volt mix. In the case of the 6v starter (motor) it will draw 1/2 the normal amps so it should last forever since the wiring is rated for double the amps now required. High amps cause wires to heat up, lower amps means cooler wires. All starters are momentary motors, not rated for continuous output, so ANY starter will burn out if run too long under load. The opposite case is best illustrated by well known "brownouts" during the summer on the east coast. Voltage drops because of overloaded circuits caused by too many AC being used. When voltage drops AC motors demand full wattage and get it by increasing amps and burning out AC motors.
Home
| Forums
| Order Support
Today's Featured Article -
My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
