Re: 6 volt starter with 12 volt system
Posted by Bob on January 17, 2005 at 10:01:06 from (66.163.134.177):
In Reply to: 6 volt starter with 12 volt system posted by Darin S. on January 17, 2005 at 09:54:44:
The 6 Volt starter will work just fine. True, it will spin up and engage with more of a "bang" than before, but as far as wear goes, if the engine is in tune at all it will start so quickly with the 12 Volt system there'll probably be LESS starter wear than before!
Post a Followup
Subject:
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
