Re: Clutch release bearing and pilot bearing
Posted by Jeff_MI on January 07, 2005 at 18:09:36 from (66.227.189.255):
In Reply to: Clutch release bearing and pilot bearing posted by Tailhunter on January 07, 2005 at 17:51:15:
I get most of my parts through Little Red Tractor Company in Nebraska.
I haven't worked on my H, but I replaced my BN clutch release bearing. I didn't have an arbor press (which would be best), so I just destroyed the original bearing with a hammer and chisel, then press fit the new bearing in with a block of wood and hammer on a flat surface. I was careful not to touch anything but the bearing with my chisel - as it came apart I was able to loosen and remove the bearing surface. It's crude, but it worked well and took about 20 minutes total.
Post a Followup
Subject:
Today's Featured Article - Tractor of the Month - by Staff. decals, dependin upon the configuration of the parent company International Harvester in the year of production. For the purpose of this article, we will refer to the tractor as simply a "Farmall Cub". This little tractor was aimed at the needs of the small-acreage farmer - farms of 40 crop acres or less and truck gardens, or for larger farms that needed an extra tractor. Seven or eight implements were initially designed for it: Plow, Disc, Backblade, Sickle-Bar ... [Read Article]
Latest Ad: 1952John Deere MT tractor [More Ads]
