Re: Battery
Posted by DAVE NE IOWA on January 02, 2005 at 16:31:14 from (66.43.204.123):
In Reply to: Battery posted by REA on January 02, 2005 at 07:25:19:
I have a friend that used to work in a battery factory. His job was to take relitivly new batteries in for repair or warrenty and raise them up in the air and drop them square on top of the work bench to fix them. Sounds stupid but if a piece of lead was floating around and shorting out the cell, the drop would dislodge it and float the scrap piece of lead to the bottom. Then out the door with alot of them, and back to the store. I'm thinking a square drop would be important and Wal-Mart may frown on a battery in small pieces for warrenty. Dave NE IOWA
Post a Followup
Subject:
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
