Re: 460 farmall will not start ....NEED LOTS OF HELP!!!
Posted by LMack on April 03, 2009 at 20:21:27 from (74.176.38.44):
In Reply to: 460 farmall will not start ....NEED LOTS OF HELP!!! posted by ky's861 on April 03, 2009 at 14:42:11:
Do use the choke. Try starting fluid. Do pull it off using another tractor with yours in high and the pulling tractor in low. Sometimes these gasoline engines can be hard to start the first time after a long set up and or major parts rebuild/replacement. Do these things only after you are certain you have spark to the plugs.
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
