Re: 12 volt Conversion
Posted by Hayfarmer on December 03, 2004 at 18:35:09 from (66.243.235.174):
In Reply to: 12 volt Conversion posted by Steve Farmall 140 on December 03, 2004 at 17:56:35:
If you go to the articles section Bob M has an excellent diagram of the conversion on an M but should be the same for yours. If you are going to do it I would use an alternator.
Post a Followup
Subject:
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
