Farmall Tractors Discussion Board
Re: Re: Re: Cracked wheel
Posted by Farmer Bob on November 19, 1999 at 21:53:53 from (207.227.187.188):
In Reply to: Re: Re: Cracked wheel posted by Wisconsin Ron on November 19, 1999 at 20:51:11:
I've also seen them crack during winter if the drain hole gets plugged up and water gets inside if tractor sits outside. Then mean ole man winter comes along and Whammo! Water expands when it freezes. FB
Post a Followup
: Re: Re: Re: Re: Cracked wheel
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
