Re: removal of super M radiator
Posted by Bob M on November 17, 2004 at 05:58:56 from (165.170.128.66):
In Reply to: removal of super M radiator posted by jnewark on November 17, 2004 at 05:02:21:
Allan’s correct about removing the front cap and “unscrewing” the shaft out of the steering box. The pivot shaft worm gear cannot be flipped over - it’s on a tapered spline and only fits one way. However if it is a full gear it can be ROTATED 180 deg and reinstalled. On the other hand if it is a sector type (half moon shaped) gear you are outta luck – it can only be installed one way. Note: If your steering is sloppy check also for wear on the pivot shaft bushings – especially the upper one. If you find ANY radial play in the upper bushing it should be replaced while you’ve got the front end apart!
Home
| Forums
Today's Featured Article -
The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
