was the tractor running before the tune up or did it break down and you are trying to get it going? as it has a lot of new parts in it, i;d do some background checking before throwing more parts at it. with the air cleaner off, give er a shot of ether and see if she starts. if so, look to a fuel problem, does the carb flood some with the choke on? if so look to ignition. at this point i would run a jumper wire from the battery + to the coil + if 12v neg ground, effectively bypassing the starting and ignition switch "hot wiring" use an alligator clip so you can disconnect the wire if it starts. see if it will start and run with the hot wire. pull a plug and check for spark when cranking it over. if you have good spark, squirt a couple pumps of motor oil in each cylinder, crank the engine a couple of times to spread the oil around, then replace the plugs, give er a shot of ether and see if it starts. the oil will help raise the compression if the rings are dry.
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
