First pull out the front plug, run that piston up to the top (TDC) on compression. Then pull off your distributor cap and point cover. See if the points have just opened.
If they have, turn the engine back about 5 degrees and hold the coil wire close to a good ground. Then rotate the rotor back and forth, breaking and closing the points. See if you're getting a good blue spark. It should jump about a half and inch.
If you have all that, you have a fuel/carb problem
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
