Antifreeze in Oil - Farmall M - Update
Posted by RandyMcC on October 26, 2004 at 16:27:51 from (24.91.32.192):
Found the leak in the block. It is a pin hole leak above the camshaft about a half inch toward the center of the block from the valve tappet. Will JB Weld work on this? Would it be better than block or radiator sealant? Randy First Post: Farmall M, which is a dry sleeve...just purchased, drained antifreeze down far enough to replace water header gasket (block about half full), pulled oil pan and replaced gasket, did not refill with antifreeze. One month later I again took the oil pan off to replace the petcocks and found quarter cup of antifreeze. I pulled the head to check headgasket. How do I know if I have a leaky headgasket? From underneath the engine I found a drop of antifreeze on the block between cyl. 2 and 3 and on the cyl. 3 connecting rod bolts. The camshaft was clean. If a cracked block what are my choices? The tractor is used about 4 hours per month. Randy
Home
| Forums
| Order Support
Today's Featured Article -
My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
