Re: 706 alternator
Posted by gusc on October 24, 2004 at 15:52:57 from (63.97.117.26):
In Reply to: 706 alternator posted by nate s on October 24, 2004 at 06:53:17:
Nate,
The R 1 or 1 spade is for an idiot light or a separate switch to 12v. It turns the alternator on. If you don't attach a light or switch this connection will run down the battery when parked and won't let you shut off the engine. I have a 641 and a JD done both ways.
The F 2 or 2 spade is hot all the time and is best connected directly to the large battery post on the back of the alternator. In a one wire alternator this connection is built into the regulator.
The large post on the back of the alt is hooked directly to the battery or to the battery connection on the starter, whichever is shorter. Use at least a 10 gagewire for this. The other wires don't need to be larger than 16 ga
Post a Followup
Subject:
Today's Featured Article - The Mud Daubers and the Old John Deere - by Jon Zehnder. I have a 1941, John Deere Model A tractor I have owned for about a year and a half. This is my first (in case my wife reads this, "FIRST") tractor and it has been a learning experience. After considerable advise and assistance from local tractor nuts and the forums of Yesterday�s Tractors, I had finally got it running pretty well. I have tuned it up, overhauled the carburetor, installed a borrowed, rebuilt magneto, installed a new Power-Trol, patched the radiator, installed new front wheels a ... [Read Article]
