Re: IH FARMALL 300 (H) I THINK HELP
Posted by Stan(VA). on October 19, 2004 at 05:22:50 from (208.59.156.246):
In Reply to: Re: IH FARMALL 300 (H) I THINK HELP posted by RICK OASIS IDAHO on October 18, 2004 at 12:31:02:
Sorry about the right/left confusion, I obviously don't have one on the place at the moment. The serial number suffix letter codes identify:
D- 5000 ft high alt pistons (higher compression)
S- Torque Amplifier & Independant PTO options
J- Rockford Clutch (maybe someone else can help here, I guess either an alternate supplier or poss considered a heavy duty clutch?)
In ordering parts I would identify it as a Farmall 300, serial num 11720. If they ask, add with the 169 cubic inch gas motor (but I don't think the diesel engine was even offered until the 350 came out). The HP number was just to answer your question, the parts guy woln't ask for it.
Stan(VA).
Post a Followup
Subject:
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
