Re: H Hydrolics
Posted by Boydg on October 17, 2004 at 15:40:45 from (208.186.57.65):
In Reply to: H Hydrolics posted by DannyH on October 17, 2004 at 12:48:40:
Danny, The 3 pipes are screwed in to the L shaped thing you are talking about. That is the hydraulic pump. Your problem is most likely a seal rather than a gasket. 4 pipes have to come out, 1 on top 1 on right side, 2 on left side, shaft that drives the pump has to come out. Pump is heavy so get some one to help you. Once it is on the ground you can get a better idea of what you have. Hope this helps Boyd
Post a Followup
Subject:
