Re: DANGED D236 IH Diesel STILL won't start!
Posted by Farmer Bob on October 06, 2004 at 09:17:11 from (64.113.14.239):
In Reply to: DANGED D236 IH Diesel STILL won't start! posted by Ibby on October 06, 2004 at 03:18:02:
Ibby, The fuel shut off control is controlled by that choke like cable that runs up to the cab. The apparatus on the RM pump should be turned to the right or clockwise for starting/running. All the way to the left is for shutting off the fuel inside the pump thus killing the engine. There should be stops on the apparatus which are set correctly during a pump rebuild.
Make sure of the glow plugs first, then make sure you are getting a good solid spurt of fuel without bubbles of air out of each of the lines to the injectors as you are purging the air out of the system. If you are getting dark black smoke out of the exhaust as it is trying to fire, I'd say you still have air in the system.
Most diesel shops would be able to rebuild your pump but it most likely will cost you several Ben Franklins. Good luck with it.
Post a Followup
Subject:
Today's Featured Article - The Mud Daubers and the Old John Deere - by Jon Zehnder. I have a 1941, John Deere Model A tractor I have owned for about a year and a half. This is my first (in case my wife reads this, "FIRST") tractor and it has been a learning experience. After considerable advise and assistance from local tractor nuts and the forums of Yesterday�s Tractors, I had finally got it running pretty well. I have tuned it up, overhauled the carburetor, installed a borrowed, rebuilt magneto, installed a new Power-Trol, patched the radiator, installed new front wheels a ... [Read Article]
