Re: 706 rearend weight / strength
Posted by Novel Idea Guy on October 06, 2004 at 08:48:50 from (64.80.110.15):
In Reply to: 706 rearend weight / strength posted by The Farmall on October 06, 2004 at 08:29:57:
The rear end casting went through several design revisions, though the basic design was definitely the same.
According to one of the IH books I've got, the gears got heavier as the tractors got bigger. I suppose much of the weight gain was from internals, not the casting itself. The major difference was when you went from the 14XX to the 15XX; instead of bull gears, the final drives were planetary.
Frankly, if you're planning on marrying a 706 rearend to anything but a 706, do so with the understanding that you could tear its guts out.
Post a Followup
Subject:
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
