Flywheel for super C - and H are they the same??
Posted by pat maplehillfrm on September 24, 2004 at 06:28:18 from (67.50.29.113):
Hello all, I have a question I think I know t he answer for already, but I couldnt find part # in my books, will the flywheel for the H fit a super C? I think the H would be bigger but wanted to check prior to removing the H flywheel, thanks for any help,,pat
Post a Followup
Subject:
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
