Re: farmall h timing problem
Posted by farmallsc on August 19, 2004 at 20:42:33 from (64.12.116.14):
In Reply to: farmall h timing problem posted by Gary lefkiades on August 19, 2004 at 20:40:00:
you can remove the distributor and hold your finger over teh hole into the cylinder adn rotate it unitl the cylinder is at its peak position adn pur your distributor back on adn set it
Post a Followup
Subject:
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
