Re: Farmall h exhaust
Posted by Anthony on August 04, 2004 at 18:50:25 from (64.12.116.14):
In Reply to: Farmall h exhaust posted by Pat Connors on August 04, 2004 at 12:51:58:
I've seen, in automotive applications, mufflers packed with steel wool to lower the noise level. It does make a difference; make sure to use a coarse grade and don't pack too tight.
Post a Followup
Subject:
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
