Re: Farmall M Crankshaft
Posted by El Toro on June 18, 2004 at 08:50:57 from (205.188.117.22):
In Reply to: Farmall M Crankshaft posted by Larry on June 17, 2004 at 20:50:01:
Hi Larry, Those bearing clearances for the mains
and rods are .002" to .003". I would measure that crank to be sure it still measures standard
and isn't under size. I restored a Farmall A and used .002" under size inserts from Federal Mogul.
The rod journals and mains were .002"
under size and the shaft looked terrible, but wasn't scored. I just had the shaft polished. It looked like new one after being degreased and
polished. I plowed the garden with it and had it out front taking pictures and a man stopped and wanted to know if it for sale. He said he had never driven a tractor and wanted me to give him a driving lesson. I let him run it 2nd gear
around the area then had him to put it 4th. He ran that tractor to his home about 15 miles from here. He had abeely mounted rotary mower installed. I saw the tractor about 10 or 12 years later and they were still mowing with it.
I restored 6 Standard Twin and Viking
garden tractors. They were made in the late 30s
ad early 40s. Most were on steel the later ones were on rubber. Most of engines were in sad shape. They used babbitted bearings on the rods. The mains were cylinder shaped. They were made in MN and used by truck farmers. I sent the rods to Federal Mogul to be rebabbitted. I had the cranks machined at a local shop. I sent the crank dimensions along with the rods.
These tractors were way ahead of their time since they used no belts. All gear driven
they used a multi-disc clutch that ran in oil. An oil pump in the differential to lube the upper gears. They even had a pto that ran out the back of the transmission.
I still have the moldboard plow from one of these tractors adapted to fit my Cub Cadet.
Hal
PS: I'd better send this before the computer dumps.
Post a Followup
: Re: Re: Farmall M Crankshaft
Today's Featured Article - More Memories of a Field Service Engineer - by Brian Dye. Introduction: The author worked for one of the largest Ford tractor dealerships in England as a trouble-shooter on tractor engines, hydraulics and combine harvesters from 1963 to 1972. In 1972 he became a dealer manager and finally left the dealer net in 1975 to run his own electronic design and manufacturing company. [Editor] We live right in the middle of Norfolk. The dealership that I worked for sold Fordson Tractors from the 1920's and some of t ... [Read Article]
