Re: FARMALL C AXLE
Posted by Ed on June 17, 2004 at 21:12:16 from (216.93.117.27):
In Reply to: FARMALL C AXLE posted by MILLARD on June 17, 2004 at 20:41:57:
I LOOKED IT UP IN MY OLD PARTS CATALOG......YOU REMOVE THE AXLE AND AXLE HOUSING, THEN REMOVE THE OUTER BEARING AND SEAL RETAINER, THEN REMOVE THE INNER BEARING RETAINER....I CAN'T TELL YOU IF ITS A PRESS FIT OR NOT, ....GET A BLOCK OF WOOD AND A SLEDGE, AND SEE IF IT WILL MOVE
Post a Followup
: Re: Re: FARMALL C AXLE
Today's Featured Article - Tractor Profile: Case VA Series - by Staff. V, VC, VI and VO). Althouh the Case VA looked much like the V, it shared no major components with its predecessor. Except for military units, the production of the Case VA was interrupted in July of 1942 due to World War II. It resumed again in 1944 and continued until 1953. It started up briefly later on in 1953 and continued on a very limited basis until 1956. The VA Series included the following models: VA: Fixed front wheel tread VAC: ... [Read Article]
Latest Ad: Wanted to buy model 65 massey ferguson 65 diesel [More Ads]
