Re: Farmall A fan assembly
Posted by gauger on April 13, 2004 at 05:37:41 from (12.155.240.196):
In Reply to: Farmall A fan assembly posted by Mike Bell on April 12, 2004 at 16:30:20:
A bushing won't help if the shaft is the problem, which it usually is. I made a new spindle, slightly oversized, and bored out the hub. Good as new. If you bush the hub, you will have to turn the spindle enough to clean it up without getting rid of the grooves for oil distribution. I originally bought one of the aftermarket fans, was disappointed in the quality and the fact that it was made in China so I decided to fix the original. See photo 4 at the link http://albums.photo.epson.com/j/AlbumIndex?u=4045430&a=30303574&f=
Post a Followup
: Re: Re: Farmall A fan assembly
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: Massey Ferguson model 65 diesel tractor [More Ads]
