Re: Farmall C Timing
Posted by Mike@NY on March 30, 2004 at 17:30:21 from (66.218.20.95):
In Reply to: Farmall C Timing posted by donwisc on March 30, 2004 at 14:20:25:
There is a mark (DC-14 I believe) on the flyweel that can be seen by removing the inspection cover as mentioned in a previous message. Also another way to check (would suggest doing along with the flywheel mark)is to remove the valve cover and watch for when both valves are closed on cylinder #1, that way you know you have TDC on cylinder 1 and not 4, as they both will line up (at least very closly) to the DC-14 mark on the flywheel. Good Luck.
Post a Followup
: Re: Re: Farmall C Timing
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
