Re: fluids for M
Posted by Dave_Id on January 11, 2004 at 18:49:22 from (67.0.157.252):
In Reply to: fluids for M posted by J.S on January 11, 2004 at 17:28:16:
80w90 gear oil works great for the tranny, but if you have lots of leaks and live in a warmer climate, you can use the 150w gear lube. For the hydraulic, use 30 wt for the belly pump, but if you don't want to cross contaminate implements, then you can use Hi Trans from IH, or whatever you use in your other hydraulic systems in other tractors. The clearances aren't very tight on the belly pump, so if you use the Hi Trans, you may experience some bleed by.
Post A Followup
: Re: Re: fluids for M
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let�s make one more addition to our series on hydraulics. I�ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
