Re: FLUID IN REAR TIRES
Posted by BIG JOHN on September 30, 2003 at 15:11:04 from (205.188.209.140):
In Reply to: FLUID IN REAR TIRES posted by FARMIN RED on September 30, 2003 at 06:31:57:
I like to remove the fluid from my tires and put it on my gravel drives. It will keep down the dust and kill the weeds. I usually position the valve stem at the bottom and remove the valve stem, not just the valve core. The fluid will shoot about 20' out from the tractor. If I don't want it to go that far then I rig some type of a deflector. Be sure not to get any of the fluid in your eyes, wear eye protection. You will need to be located somewhere where you can refill the air in the tire. (Remember you won't be able to move the tractor because the tire will be flat.) Replace the valve stem and repeat the process again until no more fluid comes out. There will still be some fluid in the tire. Take a valve stem with you to the hardware store and buy about 3 feet of plastic flexable tubing that will go into the tire thru the valve stem base. Now air the tire back up and then remove the valve stem again and put the plastic tube into the tire just far enough that the end will be at the bottom of the tire. You will need something to use around the plastic tube at the valve stem base so as not to let the air out around the outside of the plastic tube. This will force the remaining fluid out thru the plastic tube. You will probably have to repeat this several times to get all of the fluid out. Be sure to secure the outer end of the plastic tub because it will whip around and probably get you soaked. I usually use a pair of vice grips with just enough pressure to hold the tube but not squeze it closed. HAVE FUN
Home
| Forums
Today's Featured Article -
History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
