Re: grease fitting on front hubs
Posted by Randy in NE on September 12, 2003 at 04:55:57 from (216.58.237.20):
In Reply to: grease fitting on front hubs posted by SCOTT IN MO on September 11, 2003 at 17:27:36:
Keep in mind that filling the dust cap with grease isn't necessarily going to get the grease into the bearings. Especially the inner one. If your hub was designed with a gease zerk I would go for it. Since it wasn't I would personally want to take the hub off and manually pack them. I have seen people rub grease on a bearing and think that they have "packed" it. Most of these old tractors aren't being "used and abused" like they were when they were the "big" tractor on the farm. It doesn't take much to re-pack a bearing. Easier than replacing the bearing and race. Just my $0.02 worth.
Post A Followup
: Re: Re: grease fitting on front hubs
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
