Re: grease fitting on front hubs
Posted by Farmer John on September 11, 2003 at 21:08:50 from (65.240.57.70):
In Reply to: grease fitting on front hubs posted by SCOTT IN MO on September 11, 2003 at 17:27:36:
Scott
If you do put grease zerks in the dust caps be SURE and use a grease that is designed for wheel bearings and not the plain old multipurpose stuff. I had a lot of problems using multi purpose grease on disc harrows, wagons, tractor front wheels etc. that had greasable hubs. I changed bearings frequently and finally started using a grease that would cover everything from wheelbearings to 3point hitches. I use Exxon Ronex but you can decide for yourself what's best. Just don't make the mistake I made and use multi as your wheels may fall off!
Post A Followup
: Re: Re: grease fitting on front hubs
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
