Re: 450 PTO shaft from engine driving clutch
Posted by Chuck on August 27, 2003 at 17:21:22 from (64.6.15.11):
In Reply to: 450 PTO shaft from engine driving clutch posted by Bob K on August 27, 2003 at 12:42:18:
It sounds more like your pressure plate is not releasing the clutch disc when you push in the pedal.Either disc is sticking or broken (piece of disc wedged between disc and pressure plate)or pressure plate out of adjustment or broken. You don't say if you had free travel before you split the tractor or if the pedal felt normal. I think the clutch is where I would start looking. My 2 cents worth....
Post A Followup
: Re: Re: 450 PTO shaft from engine driving clutch
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in. ... [Read Article]
