Re: IH 3688
Posted by K.B. on June 24, 2003 at 12:58:38 from (209.163.43.29):
In Reply to: IH 3688 posted by tf on June 24, 2003 at 06:45:44:
The big thing is probably the TA. On the 3088 series, the TA is shifted electronicly. The speed lever allows you to select 8 speeds with 2, 4, 6, and 8 being direct drive, the same as 1, 2, 3, and 4 on the 706-1486. Shifting to 1, 3, 5, and 7 engages the TA. It's supposed to be a much better setup than the mechanical shift linkage on the older tractors, because it can't come out of ajustment. The other big thing to check is the cooling fan, which sits in front of the radiator and is driven by a shaft that sticks though the radiator. I belive there is a bearing in the radiator that the shaft rides on that needs to be checked. Other than that, check it out just like you would check a 986. We just got a 3088, great tractor.
Post A Followup
: Re: Re: IH 3688
Today's Featured Article - Torque Wrenches - by Curtis Von Fange. When working with fasteners a torque wrench can play an important role in the correct assembly of critical equipment components. Lets examine in detail some of the reasons for using a torque wrench along with how to correctly use the variety of wrenches available. Applying the proper torque to a fastener accomplishes a number of tasks. First of all correct torque will hold the parts together. This may seem like a trite statement but � think about it for a second. Engineers have designed ... [Read Article]
