Re: Farmall Cub oil pressure problem
Posted by Bus Driver on May 31, 2003 at 14:41:58 from (65.165.153.2):
In Reply to: Farmall Cub oil pressure problem posted by Gaetan in QC on May 31, 2003 at 07:22:02:
Prime the oil pump. Not an unusual happening on a Cub when not run for extended periods of time. On the left side of the engine at the back of the block- in the edge of the flange- hidden under the hydraulic lines if you have them- there is a small Allen head plug. Remove the plug and using a pump oiler, pump the hole full of the same oil used in the engine- requires very little. Reinstall the plug. Avoid running the engine without oil pressure.
Post A Followup
: Re: Re: Farmall Cub oil pressure problem
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
