Re: super A overhaul
Posted by Gary-Miss on March 18, 2003 at 20:45:41 from (152.163.189.203):
In Reply to: super A overhaul posted by Hal` on March 18, 2003 at 17:43:22:
It is a simple task to pull the valve cover back off. Pistons # 1 and 4 come up the same time, one of them on compression, the other on exhaust, the same on pistons # 2 and 3. Turn the motor over slowly, preferably with a crank. As # 4 piston comes to the top on exhaust, the exhaust valve will be open. At EXACT top dead center, the exhaust and intake will be "on the rock" ie: one will be closing, the other will be opening. Make certain that your distributor rotor is pointed at # 1 plug wire, continue around through the firing order. Remember, watch for movement on the OPPOSITE cylinder from the one that is on compression stroke.
Post A Followup
: Re: Re: super A overhaul
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: WANTED IH C200 gas engine — complete running motor Wanted complete used IH C200 gas engine in running condition for an International 574 gas tractor. My block has a hole in it and is dead, so a rebuild kit wont do it — need a whole running motor. The C200 also came in the 544 and 674 gas trac [More Ads]
