Re: F-20 valve lever oil trough felt
Posted by Bill Smith on February 27, 2003 at 08:31:06 from (128.242.4.59):
In Reply to: F-20 valve lever oil trough felt posted by Tom-OH on February 27, 2003 at 06:43:21:
There are two troughs. Each trough has 4 holes in it. There should be a strip of felt poking into each hole. If you put each end of a peice of felt in a hole, you would only need two pieces of felt per trough. The main thing is, that you get it put in there correctly, or it won't do much good. You will need 4 peices minimum. The felt, plugs the hole up and causes the oil that is added to trough to be soaked up into the felt. The felt that is plugging the hole, allows the oil to be slowly dripped on to the rocker arm assembly. This is the only way the rockerarms and so on under the valve cover is lubed. That is why it is important to do it right.
Post A Followup
: Re: Re: F-20 valve lever oil trough felt
Today's Featured Article - The Day Mom Drove the 8N - by Brian Browning. My Dad was wanting to put in a garden but couldn't operate the 8N and handle the old horse drawn plow he had found and rigged up to use with the tractor. Well, he decided to go get Mom out of the house and have her drive the tractor while he walked behind the plow. You got to understand that while my Mom is a hard worker who will always help whenever she can... she had never operated farm machinery before that day. Dad got her out there, explained how the clutch was the same as in our o ... [Read Article]
