Re: 450 Farmall Block heater How many watts?
Posted by jal-SD on February 25, 2003 at 12:08:18 from (12.17.66.111):
In Reply to: 450 Farmall Block heater How many watts? posted by Adam From Wi on February 25, 2003 at 07:35:21:
I've got a 1,500W on my H-only takes about an hour to get it warm. If you plan on leaving it plugged in all night, go for a smaller one, but if you plan on plugging it in an hour or two before you use it, go for the biggest one you can get. The big ones will open the stat if its above zero & you leave them on too long. I've never had a problem with mine opening the stat if its below zero. (My $0.02 worth. jal-SD)
Post A Followup
: Re: Re: 450 Farmall Block heater How many watts?
Today's Featured Article - Tractor Generators - by Chris Pratt. As a companion to the articles on three-brush and two-brush generators, it seemed fitting that we should provide our readers with a description of how a generator works in lay terms. The difficulty with all those "theory of operation" texts is that they border on principles of electricity or physics and such. Since I know nothing of either, you will have to put up with looking at the common sense side of how generators work which means we " ... [Read Article]
