Re: F-20 Oil capacity
Posted by Bill Smith on February 13, 2003 at 20:04:02 from (63.147.130.146):
In Reply to: F-20 Oil capacity posted by Ben Haag on February 13, 2003 at 19:49:23:
On the front right of engine (in front of magnito) there is a cap that unscrews. It is maybe a little bigger around than a pop can. This is where you dump the oil in. Fill to the top petcock on right side of oil pan. You will have to unscrew the petcock a little and oil should come out there when it reaches that level. Not possitive on the amount it will hold but probably in the 4 to 6 quart range. Just slowly dump untill it comes out of petcock. Start tractor and allow the oil filter to fill up and shut it back down. Then fill to the petcock again for the missing oil that is now in filter.
Post A Followup
: Re: Re: F-20 Oil capacity
Today's Featured Article - Talk of the Town: Miracle Formula for a Stuck Engine - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: I have a stuck 4 cylinder engine. Two pistons right at the top, other two down. From underneath everything looks good. Up top looks bad. Thanks in advance." ... [Read Article]
Latest Ad: Looking for a minneapolis moline zts [More Ads]
