Re: six to twelve volt question
Posted by Bob M on January 31, 2003 at 06:16:35 from (165.170.128.68):
In Reply to: six to twelve volt question posted by Bryce Andreasen (Magnum) on January 30, 2003 at 18:44:16:
Bryce - You CAN use the large wire running to the generator, providing it's still in good condition: At the front end, connect the wire to the alternator "BAT" terminal. At the voltage regulator, disconnect the wires from the regulator BAT and GEN terminals, and connect those two wires together. (Be sure to tape the connection securely to prevent it from grounding!) You will now have the path from the alternator thru the ammeter to the battery. (Note: If your tractor was orginally positive ground, you will also need to swap connections at the ammeter - otherwise it will read backward...)
Incidentally you don't need to ground the alternator - it will be adequately grounded through the mounting bracket.
Post A Followup
: Re: Re: six to twelve volt question
Today's Featured Article - A 1937 John Deere Unstuck - by Gary Hickman. Here is my story of how I got the pistons out of a 1937 JD B that the engine had been stuck for about 14 years: About 12 years ago my Dad gave me one of the tractors I ran as I was growing up on our farm in central Nebraska. The engine on this tractor, a 1937 John Deere "B", had been stuck for 2 years before he gave it to me. This last spring (1999) I hauled the tractor to our 2 acre lot in St. Libory Nebraska where it joined my antique machinery collection, at that time a 1929 Caterpillar T ... [Read Article]
