Re: C to Super C
Posted by gene b on January 23, 2003 at 03:34:08 from (67.233.170.170):
In Reply to: C to Super C posted by ryan schmit on January 22, 2003 at 17:28:13:
Go ahead if you want the pump. It is a bolt up deal you will have to have the fan belt for a C with water pump. The upper outlet is for a thermostat and the size is different than your radiator therefore hose will be problem with the two sizes from radiator to the housing. There are lots of pumps running without a therm.Whil you have everything apart clean the lower part of the block as is is probably got junk in there. You will see that the two radiators are different. Also the grilles are not the same providing that the otherC is a SUPER.
Post A Followup
: Re: Re: C to Super C
