Re: TD-9 deisel pump prime
Posted by Bob M on January 02, 2003 at 15:10:01 from (24.169.120.229):
In Reply to: TD-9 deisel pump prime posted by Roger A. on January 01, 2003 at 19:37:29:
Here's how to do it:
1 - With the main tank filled with diesel and the engine stopped, open the bleeder on the diesel water trap (if equipped) and the primary filter. Close when the bleeders flow fuel with no bubbles.
2 - Start the engine and let it run on gas, then open the secondary fuel bleeder until it flows air-free fuel.
3 - Now advance the governer (speed) control part way, then open the bleeder at each injector one at a time. BE CAREFUL HERE! - Don't let any part of your body get near the fuel that might escape from an open bleeder valve - it can be lethal!!
4 - Now throw the starting level to the "run" (diesel) position - if the system is air-free the motor will now run.
Good luck!!
Post A Followup
: Re: Re: TD-9 deisel pump prime
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
