Farmall Tractors Discussion Board |
Re: Farmall A runs and then sputters to death in 20 minutes
Posted by p on August 26, 1999 at 10:00:46 from (209.186.155.116):
In Reply to: Farmall A runs and then sputters to death in 20 minutes posted by Marty on August 26, 1999 at 06:44:29:
Sounds to me like it is running out of fuel. when a motor is running low on fuel it causes a lean condition and is a hotter ignition, causing the tractor to run hotter. I would check the tank, the glass fuel bowl under the tank(I assumes it has one) and then the bowl in the carb. Good luck.
Post a Followup
