Re: Re: difficulty of carb rebuild
Posted by Allen R on November 06, 2002 at 11:47:51 from (168.9.128.84):
In Reply to: Re: difficulty of carb rebuild posted by Slappy on November 05, 2002 at 04:41:53:
Take your time, I always use the half rule - rebuild the top half and then the bottom half, I have done many over the years - this keeps you focused on the location of each part - draw you out a little note page, write down where that piece came from (even trace a sketch of it)on your paper to size. Soak in the cleaner a day or two, that stuff is stong don't get it on you, use a pair of vice grips or long pliers to remove basket, wash the parts well with water before handling then dry and spray some WD40 or similar oil to remove any remaining moisture. Be alert to how the float was removed and the spring that holds it to the needle - I have always used a local NAPA or Carquest - prices range from $18 to $23...I do not put the throttle shaft in the cleaner or this is the part that holds your butterfly valve in the throat as it has a rubber washer that the cleaner will disolve, just clean it with spray carb cleaner as needed...The basket will hold all of your small pieces but probably not the top and bottom sections after disassembly.
Home
| Forums
| Order Support
Today's Featured Article -
Torque Wrenches - by Curtis Von Fange. When working with fasteners a torque wrench can play an important role in the correct assembly of critical equipment components. Lets examine in detail some of the reasons for using a torque wrench along with how to correctly use the variety of wrenches available. Applying the proper torque to a fastener accomplishes a number of tasks. First of all correct torque will hold the parts together. This may seem like a trite statement but � think about it for a second. Engineers have designed
... [Read Article]
Latest Ad:
65 massey ferguson diesel
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
