Farmall Tractors Discussion Board
Re: Re: Re: fluid in the fan cover
Posted by Rick K on August 25, 1999 at 05:53:26 from (205.181.231.254):
In Reply to: Re: Re: fluid in the fan cover posted by Rick K on August 24, 1999 at 07:29:49:
I checked the manual last night. I pretty much remembered right. Rotate the hib so that the fill/drain hole is horizontal and fill it up, then rotate the hub so that the hole is at the bottom and let the excess drain before you put the plug back in. Might want to do if often for a while untill the milky color goes away.
Post a Followup
: Re: Re: Re: Re: fluid in the fan cover
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: John Deere 750 Diesel Yanmar J80TU engine. pistons and rings replaced when discovered crankshaft was bent. 3995 OBO Pictures available upon request [More Ads]
