Re: Rebuilding carb
Posted by Allen R. on October 02, 2002 at 06:18:36 from (168.9.128.82):
In Reply to: Rebuilding carb posted by Randy on October 02, 2002 at 05:42:37:
Randy, as a general rule I always rebuild although
I have known others who can get by with good
cleaning.. Be sure your gas supply is clean from
tank, you may also need to flush and clean tank,
lines, I always put an in line filter on. Now as
to carb clean or rebuild - seperate the carb into
top and bottom sections - there will be four bolts
to do this - use good and correct size screwdrivers as you don't want to strip or damage
any carb parts - once you've done this repost or
e-mail me and I will assist thru process....Good Luck - Allen R...
Post A Followup
: Re: Re: Rebuilding carb
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
