Re: 400D Wiring Issue
Posted by Sven on September 23, 2002 at 07:27:20 from (207.230.238.66):
In Reply to: 400D Wiring Issue posted by David Bean on September 22, 2002 at 21:22:03:
Your correct so far. If you take the cover off the manifold switch you should see a shaft that rotates a copper plate that makes contact with the two studs. That shaft is connected to the butterfly valve setup in the manifold. The idea was to cut power to the coil when running on diesel. The previous owner probably dismanteled the switch in some way.
Post A Followup
: Re: Re: 400D Wiring Issue
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: WANTED IH C200 gas engine — complete running motor Wanted complete used IH C200 gas engine in running condition for an International 574 gas tractor. My block has a hole in it and is dead, so a rebuild kit wont do it — need a whole running motor. The C200 also came in the 544 and 674 gas trac [More Ads]
