Re: 1206 PTO problems
Posted by the tractor vet on September 22, 2002 at 18:36:30 from (216.196.13.171):
In Reply to: 1206 PTO problems posted by T16 on September 22, 2002 at 15:34:57:
If it has sliped then the clutches are fried and since you are useing it on a chopper the i would install the 7and 9 setup this is the heavy duty clutch pack and you need a special fitting to read the pressure, when i set them up i bring the pressure up to around 265-275 psi. hot . When pulling the pto out of any of the 06thru 88 series you must tip the rear of the pto downward and not hit the pickup tube when pulling it out , it helps to remove the top link bracket as then you can see what you are doing. Instaling just the clutches all ya need is a 3/4 socketand a 10-12 inch ext. a 1/2 inch drive ratchet and a pair of side cuters to pull the cotter pins and a screw driver , BUT there is one bolt way down under on the left hand side on the bottom that some people foget to take out and then try pryen the unit out it is a short 1/2 inch bolt so look before ya pry , i always put a pice of pipe over the 540 shaft and use a cheery picker and chain as it is not lite. If all the bolts are out it darn near falls out.
Post A Followup
: Re: Re: 1206 PTO problems
Today's Featured Article - Haying Before Tractors - by Owen Clark. Hi guys! At age 8 (1927, am now 79) I was learning how to drive a stacker team on the old homemade A-frame wooden stacker, on three of my uncles` dairy farms in Star Valley Wyoming (south of Jackson Hole, on the Wyoming-Idaho border). There was one steam tractor in the Valley, owned by an entrepeneur who used it to run his grain threshing machine, that he hauled from farm to farm for the fall harvest. We used teams of horses not only on the stacker, but on the buckrake to buck the dried ... [Read Article]
